Zum Hauptinhalt wechseln
The Ford Explorer and the Mercury Mountaineer were both updated for the 2006 model year on a new frame, produced by Magna International rather than Tower Automotive.
25 Fragen Alle anzeigen
My 2007 explorer rear wiper issue not working
  1. My rear wiper motor won’t work I swapped out 2 other rear wipers motors and still can’t get it to work would it be the wiper switch the front work with switch but only can get the fluid to spray back window but not the wipers to work…anyone got a suggestion
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi,
Have you checked that fuse #12 in the passenger compartment fuse panel is OK, you didn’t say?
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Yes I checked all fuses I do get a faint click noise when I try to turn on rear wiper
von
Where is the fuse compartment in the passenger side bc I dont get anything but fluid when I try to use my rear wiper
von
Hi @Earl Mullins,
The passenger compartment fuse panel is in the passenger compartment on the driver’s side.
There isn’t a fuse panel on the passenger’s side of the passenger compartment
Here’s an image taken from the 2007 Ford Explorer owner guide (p.281-282) showing the location of the passenger compartment fuse panel and the fuse location in the panel and its’ functions
(click on image to enlarge for better viewing)
Bewertung 1
Antwort hinzufügen
jamie33kenney wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 39
Insgesamt: 3,002
