Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
2264 Fragen Alle anzeigen
Home button does not work and turning on take too long
Hello.
I had to replace the screen of my iPhone 7 like three times. The first time everything works fine. However, the screen was cheap, so it failed after two months. Then I replaced it again, but this time the home button did not work. I broke the screen again and this time the home button still does not work but when I turn the phone on, it takes like three minutes. Did I misconnect something inside?..
Any suggestion?
Thank you
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
I will try to help you. Form what I know some iPhones have it so that it only works with the home button it came with. If you have the original home button then you can swap it out and hopefully it will work. You can also bring it to your local mall, they may have a place where you can get it fixed. Sorry if this was not help full, bets of luck.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Albert wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 26
