Zum Hauptinhalt wechseln
A 16 GB Android tablet with a 7.9 inch display manufactured in 2014 by Xiaomi.
29 Fragen Alle anzeigen
My pad is cracked, has black dots and is hung...can it be repaired?
I dropped my pad now its screen is cracked, it has black spots and vertical colourful lines, its hung, and also won’t respond if I click the home button (home and back are being displayed)….will it work again?? can it be repaired?? please help me
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Yes, you can fix this. However you will need to buy a new screen and digitizer assembly.You will also need to buy new 4 MM adhesive which I have linked to also.
https://www.parts4repair.com/complete-sc...
Tesa 61395 Tape
Here’s a tutorial on how to do said replacement/repair. You will need to heat up the bezels of the screen so that the old adhesive melts and then you can use an opening pick or something of the like to peel the existing screen off your tablet.
https://www.youtube.com/watch?v=ELQj_dwQ...
Tesa 61395 Tape Bild
Produkt
Tesa 61395 Tape
$5.99
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Kassidy wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 64
