Zum Hauptinhalt wechseln
The Canon EOS Rebel T2i is a continuation of Canon's entry-level line of DSLR cameras, the Rebel series. Also known as the EOS 550D and the EOS Kiss X4.
37 Fragen Alle anzeigen
SD card won't lock in, card cannot be accessed when door is closed
The SD card to my second-hand EOS Rebel T2i does not lock into the slot. When I shut the door to the SD slot the camera displays “Card cannot be accessed, Reinsert / change card or format card with camera”. I have formatted my SD card with both my camera and a program on my computer to no avail, I have also tried changing the SD card which also changed nothing. I have attempted to look in my town for a camera repair place, but I don’t want to give it to cannon because they are way too overpriced, as i bought a battery marketed as $50 for ~$7.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It sounds like something inside the slot has got bent, maybe through insertion of a foreign object. Looking into the slot with a magnifying glass while illuminating it with a torch may enable you to see what’s wrong, and there’s some small chance you could bend it back with a jeweller’s screwdriver or other long thin object.
Your best chance may be to look out for another camera of the same model offered on eBay as “spares or repair” in order to cannibalise it for the appropriate spare.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Logan Elias wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 925
