Zum Hauptinhalt wechseln
Das Samsung Galaxy Note 5 ist eine Kombination aus Mobiltelefon und Tablet von der Firma Samsung. Es kam im August 2015 auf den Markt.
271 Fragen Alle anzeigen
My phone works but the screen is black
i have a samsung galaxy note 5 , everything seems to be working fine the button lights lite up and i hear sound but the screen is completely black and i have tried Press and hold the following three buttons at the same time: Volume Up key, Home key, and Power key. ... is there anything else i can do to fix this problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Hey guys I have a great quality zx-5361 laptop and I'm trying to figure out how to turn on wifi connection for it cause I press the button that shows it for but it won't connect
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
If you shine a flashlight onto the screen (shine it at different angles too just to be sure if you don't see anything at first) do you see anything? If you see nothing, the problem is more complex then just a backlight issue.
The next possibility is that your phone’s screen display cable has come loose and needs to be re-aligned. Use the guide below to be able to get to the phone’s display cables.
The third possibility is that the screen is no longer working and requires replacement. Be sure to try the options above before replacing your screen! You can use the same guide below for replacing your phone’s screen and I have also included a screen replacement guide too.
Samsung Galaxy Note5 Display Replacement
Galaxy Note5 Screen
Galaxy Note5 Screen Bild
Produkt
Galaxy Note5 Screen
$119.99
War diese Antwort hilfreich?
Bewertung 1
i also have a note 5 sm - n920v and it were off for a while because my screen break buh now i buy a new one the screen showing phone charging and coming on after it show Samsung the first time it suppose to show it again then Verizon it doesnt i dont know whyy i seeing it on buh its blank i putting my password it works buh i cant see
Bewertung 1
I have also note 5 duos N9208 and i also face this problem and i try power key and volume down key press for 10 sec and first time this method work and after 4-5 hour screen gone freeze and i try but not work and i do more times then that day also work and 3rd day also happend this problem and after that i have try all method but not work screen gone black and touch also not working so i take my phone to nearby shop but there are not best shop because it’s hill side i live in, then i backed home and i thought that display connector might be disconnected so i hardly open back glass by a lance and old xray paper piece to remove back glass i don’t have special tool kit to open, so i heated back glass by lance with sun light and then open by xaray paper piece and finally open and i remove battery connector and display connector and touch connector from motherboard and again connect properly and then it’s work mobile switch on with i’s logo then i really happy
Bewertung 0
Antwort hinzufügen
redrage75 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 31
Insgesamt: 3,692
