Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
All movement sensors malfunctioning
Simply put, as the title says. Have attempted:
-Software reset(on phone)
-Starting phone without any of the screws on the LCD plate.
Most notable fault is the phone not rotating. Below are shots of the app I use to check sensor data. To the left phone are the correct values:
Proximity and light sensor fully functional. No water damage shown on indicators.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
have you just replaced the screen?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
For the fun of it, I downloaded the app on my phone to compare results. My readings match those on the left (top).
There are several sensor IC’s inside the iPhone.
  • Compass IC
  • Barometer IC
  • Accelerometer & Gyroscope IC
  • Motion CPU
They are all powered by the same voltage rail so multiple failures may point to a voltage issue. The Gyro IC is also sensitive to water, whether it be water damage or ultrasonic cleaning. At this point, you may want to have the phone looked at for some board level diagnostics.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
After two weeks, it would appear that local shop could not find a solution to the problem.
They may be starting to hate me for all these phones I send out to them with no solution.
von
You need to become an expert micro-solderer/board whisperer and outsource your services to them instead ;>).
von
Antwort hinzufügen
Smeargle wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 70
