Zum Hauptinhalt wechseln
2,2 GHz (Turbo Boost bis zu 3,4 GHz) oder 2,5 GHz (Turbo Boost bis zu 3,7 GHz) Quad Core Intel Core i7 Prozessor mit 6MB geteiltem L3 Cache.
451 Fragen Alle anzeigen
MacBook Pro - How to use external monitor right from boot/login screen
My macbook's display is not working, and it just shows some lines for most part of it. But I can see(barely) it is booting and waiting at login. I want to connect it to external display and take a backup. The problem is that the external display becomes secondary display and I do not see the login prompt on it to work.
Is there a way to make the external display the primary display or to mirror display using some keyboard shortcuts, as I cannot see whats on the screen at all?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
If you have access to a USB or Bluetooth keyboard & mouse. Restart your system and then close the lid so the lid sensor acknowledges the lid is closed your external display should automatically become the primary display.
If this fails you may have something deeper here than just a messed up LCD.
War diese Antwort hilfreich?
Bewertung 13
4 Kommentare:
Brilliant! Worked for me.
von
You need the magsafe in and power on too. It doesn't work from battery.
von
Worked for me
von
worked for me too :)
von
Here’s a guide on how to do so. Pretty cool guide in my opinion!
http://osxdaily.com/2010/12/21/broken-ma...
Bewertung 1
2 Kommentare:
@ajcooke01 - Be careful! This guide was for the older A1211/A1212 MacBook Pro. The newer MacBook Pro retina series are a bit different. I wouldn't disconnect the display lid as you would loose Bluetooth & WiFi
von
@danj I didn't say to disconnect the lid, it was just in the very unlikely case the OP would actually do something like that.
von
I'm trying to connect Mac book pro 2019 from usb c to HDMI cable to Samsung TV before login. But it's not detecting in TV even after connecting charger and closing lid. Any idea why?
Bewertung 0
1 Kommentar:
Try a different port, adapter and/or cable as one is not working properly.
von
So i have a macbook with usb-c/touchbar with a broken display and other boot problems.
The screen doesn't do anything and the touchbar sometimes shows something, the capslock light is working but no external screen, even with the lid closed/charger connected/external keyboard amd mouse. Any idea where to start?
Ps. I got internet recovery to work on the external screen but it was in extended desktop mode so i could really see anything....
Bewertung 0
Antwort hinzufügen
Harish wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 55
Letzten 7 Tage: 390
Letzten 30 Tage: 1,634
Insgesamt: 74,027
