Zum Hauptinhalt wechseln
2.0GHz, 2.3GHz, oder 2.6GHz quad-core Intel Core i7 Prozessor (mit Turbo Boost bis zu 3,8GHz) mit 6MB geteiltem L3 Cache.
580 Fragen Alle anzeigen
Need help finding part or part number
Got a machine in that had been repaired by a competitor. They were supposed to fix the trackpad. They didn’t and they left out the trackpad cover plate. I’m looking for that part or part number. Without it the trackpad won’t click correctly.
@blakeklein
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
@mayer - I’ve not found it missing or damaged enough to interfere with the trackpad. But I think you could fashion a replacement plate out of a soda can carefully cutting out the tubular section from the top & bottom parts and splitting it down the side. Then shaping it so it lays flat and cut out the matching the original or a paper template. The other option is just getting a sheet of aluminum from a metal supply house that is the same thickness the original is. You’ll want to give it a coat of urethane paint so its insulative.
If you want the real deal here’s a source: TheBookYard - Retina MacBook Pro 15" Trackpad Insulating Cover The part number is not correct as its for the full uppercase.
War diese Antwort hilfreich?
Bewertung 3
4 Kommentare:
When do you go in for your ablation procedure? Email me when and where please!
von
@danj my thinking is not real clear right now due to the heart problems ( the cardio version didn't work so we'll go for an ablation next). Is the plate needed so the trackpad will click? It tracks just fine. But there seems to be nothing to hold the pad up.
Yup, that the part I need but now have a new word to search for it ;-)
von
Yes, my dad had the same issues of cloudy head before he went in. Hang in there! Please let me know when and where.
As far as the trackpad: Yes its important as the battery will block the trackpads depression.
von
@mayer Best of luck with the ablation procedure! Sending positive energy your way. :-)
von
Antwort hinzufügen
mayer wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 5
Insgesamt: 114
