No backlight after battery replacement .
Hello all,
I was able to replace battery on my beloved Pebble Steel but back light and charging diode is not working anymore - I soldered battery using Ifixit workaround but battery is soldered not using stripe (sorry for terminology - I am not expert) but is soldered on wires. Did I heat it too much and destroy some circuit related to back light or how to proceed at this moment.
I know it is not usual to fix things like that while this watch are almost not available and I am not willing replace them by some different smartwatch with touchy display …There is at least one user who experienced and fixed this issue - Andrew Morton , Sindre Bjerke @sindre
Ist dies eine gute Frage?
The same happened to me, and it might be related to insufficient pressure over the battery area, or positioning of the plastic cage inside the steel case. I can't say for certain. What I can say is that with repeated teardown and reassembly looking for the problem, both eventually (and simultaneously) started working again.
von HonoredMule
