Zum Hauptinhalt wechseln
Im Juni 2017 brachte Apple die Neuausgabe vom 13" MacBook Air heraus. Es erhielt den neueren Broadwell Intel Core i5 Prozessor, die Leistung und Akkulaufzeit stieg dadurch etwas an.
423 Fragen Alle anzeigen
My battery is dying really quick. What could be the issue?
All of a sudden, my battery started to die really quickly. My battery used to last around 6-7 hours and now only lasts 2.5 hours on normal use. My Macbook is an year old. Apple Genius Guy says that there is liquid damage but my laptop is working just fine (other than the battery, of course). I even reset it. Still the battery life is the same 2.5 hours. Tried SMC and PRAM reset, no effect. I have attached coconutBattery’s screenshots.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Can you please help me I installed the battery into my macbook pro 2014 a few months ago and everything was fine and now it's only operating at 50% capacity and i'm getting less than 4 hours life on it. I have tried a battery calibration, a SMC and a PRAM reset and i still get a "service recommended" warning on the battery
Can you help me please?
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Battery values are excellent, charging power seems to be flawless. I believe battery is innocent here and something is draining it beyond the acceptable..it might be a software or a hardware issue. To check what’s happening on software side, find activity monitor in utility folder inside applications folder. Launch it and select from menu to list “all processes” and see if there’s something using an unusual and unjustified amount of Cpu. Check what’s the average value of Cpu used during a normal session to see if anything is keeping it busy beyond the ordinary. If Cpu stays below 20% on average and battery gets drained at the speed you indicate something might be absorbing power on the hardware side.
War diese Antwort hilfreich?
Bewertung 4
Let’s do some testing of your battery. Complete the guide below; upload 2 screenshots to your existing question, one with the MagSafe adapter in and one with with the MagSafe adapter out.
How to Test a Mac Laptop Battery
Update (10/30/2018)
@mishragaurav Your full charge capacity is lower then your design capacity, it’s time for a new battery.
MacBook Air 13" (Late 2010-2017) Battery
MacBook Air (13 Zoll, Anfang 2015) Akku austauschen
MacBook Air 13" (Late 2010-2017) Battery Bild
Produkt
$69.99
MacBook Air 13" Early 2015 Akku Bild
Anleitung
Schwierigkeitsgrad:
Mittel
15 minutes
Mac Laptop Bild
Anleitung
Schwierigkeitsgrad:
Sehr einfach
3 - 5 minutes
Bewertung 1
4 Kommentare:
@ajcooke01 hi, thanks for taking time and effort to help me out. It really means a lot.
I have added the screenshots.
von
@ajcooke01 I agree battery is below full design capacity, but I (strongly) disagree a battery with such figures needs replacement..any battery after a few charging cycles is not 100% and every battery above 80% capacity can be considered good enough. Please include that in your battery testing guide ;)
von
@arbaman I have a hunch that it is just a crappy battery. Design capacity good or not, I think that is the scenario.
von
@ajcooke01 I have a hunch you have plenty of good will but a bit more of experience might help :) We all have a tendency to see troubles we know more often than the ones we don't have a clue about. That's the reason why doctors discourage people from self diagnosing =;)
von
As you can see by the pictures the battery is fairly degraded almost 30% less than normal also Is this battery aftermarket? I hope this can help
Update (10/30/2018)
OK, thanks thats what I needed to know did it start doing this after an update because this could be a software issue with mac OS and just an FYI apple will always say there is water damage because the sensors are set off even by a little bit of mist but you could try backing it up and resetting it
Bewertung 0
14 Kommentare:
Have a closer look, you're mistaken.
von
it says battery health is 62 percent and design capacity is 96.9% so that's where I got that, also have you tried backing up mac os and restoring it this could help the problem
von
The battery is original and out-of-the-box. As I told you, I bought it last September. The system is fairly new.
von
@ifixiphone David, I have restored and backed up the same but to no avail.
von
Oh sorry I didn't see that you already said that sorry
von
9 weitere Kommentare anzeigen
Antwort hinzufügen
Gaurav Mishra wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 11,178
