Zum Hauptinhalt wechseln
Veröffentlicht am 16. September 2016. Modelbezeichnung 1660, 1778. Verfügbar in den Versionen: GSM oder CDMA / 32, 128 oder 256GB / Rosé Gold, Gold, Silber, Mattschwarz oder Hochglanz-Schwarz
2264 Fragen Alle anzeigen
iPhone id disabled, connect to itunes
My iphone is disabled and message coming up on screen is iphone is disabled, connect with itunes.
Is there anyway to backup my phone. I know my correct passcode.
Also when i am connecting my phone to PC, phone is not getting recognized.
Please help
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Sorry to hear you’re locked out. To confirm, your phone says “iPhone disabled” right? There is some advice I can provide, but I’m not sure you’ll like it.
Once disabled, you either need to wait for the count down timer to complete and enter the correct passcode, or erase and restore the device.
If the iPhone has not been synced to this PC before, you will not be able to back it up either. Hopefully there will be an iCloud backup that will have been made before it was disabled.
You can review the full steps to erase the device in iTunes here: https://support.apple.com/kb/HT204306
You said the phone isn’t recognised in iTunes. You can update iTunes from https://www.apple.com/itunes and if needed, you can remove and reinstall the full software by following the steps here: https://support.apple.com/kb/HT204275
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
Hey,
I am not getting option to re-enter my passcode. Message showing up on phone is iphone is disabled, connect to itunes.
My phone is not backed up earlier too and there is no backup on iclouds too.
I know my passcode , is there any way to backup data ?
Thanks
von
That is a sticky one.
If the phone has previously synced with a computer, you can connect the phone to that computer to make a backup (https://support.apple.com/kb/HT203977).
If you do not have access to a computer that previously synced, your only option is to erase and setup as new (https://support.apple.com/kb/HT204306). That will remove ant data I’m afraid.
von
Hello Ratika
Put the iPhone in DFU mode and then remove it in that way with programs like U3tool? Only an idea that may not work.
The other option would be to update the terminal. In some occasion that has solved this problem, but if it does not recognize it is more difficult ...
Luck
Bewertung 0
Antwort hinzufügen
Ratika Gulati wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 88
