Zum Hauptinhalt wechseln
4-Zoll iPhone herausgebracht im März 2016 mit ähnlicher Hardware und Spezifikationen wie das 6s. Erhältlich in Silber, Space Grau, Gold oder Roségold mit 16/64 GB Speicher. Modell A1662 und A1723.
1049 Fragen Alle anzeigen
Name of this component for iPhone SE?
Hello, which is the name of this component for iPhone SE? First time with my broke iPhone when I tried to replace motherboard, this component has been removed from iPhone. Which is the function of this component? And is possible repair it with a something as the welder? Because I noticed it is attached to iPhone.
Image of component:
Thank you in advance for reply.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
That’s a teared off part of the wifi/bluetooth antenna. It’s a pretty inexpensive part but you’ll have to buy a new one. No need for soldering, it’s simply glued to the housing.
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
@refectio That's where it was hidden, thanks for the addition =:)
von
That’s part of the rear case. You can see it in this photo from the teardown, and this one too.
To get WiFi/cellular connection, you’ll need to buy a new rear case, since the connector is permanently attached to it, and can only come off if the cable is torn. It looks like you can relatively easily get new (though not necessarily OEM) cases on eBay.
Bewertung 0
2 Kommentare:
No, there's no need to replace the housing, it's sufficient to buy the new antenna and replace the part of the old one left, some warming makes the job easier.
von
Oh, I had no idea that it wasn't part of the rear case!
That's nice to know. Thanks for clearing that up!
von
Antwort hinzufügen
Patrizio Masini wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 82
