My dishwasher has water standing in the bottom.
I have checked the drain, there is no garbage disposal. I have checked the drain line and it is clear. I have cleaned all the filters. Replaced the drain pump and turbidity sensor but still water in the bottom. What am I missing? It’s a whirlpool WDF530PLYW7 model
Ist dies eine gute Frage?
5 Kommentare
Hi @jbailey1978 ,
Place the drain hose into a bucket and run a cycle to check the drain flow pressure.
Also is the drain hose looped up above the main drain pipe connection?
von jayeff
How much pressure should there be? And the drain line is looped
von Janet
Hi @jbailey1978 ,
Can't give a figure on the actual pressure that should be there. Just so that it appears to come out with some flow to it and not that is seems to be sluggish or impeded
von jayeff
Almost no pressure. Barely dripping when it’s set to drain.
von Janet
So far no solution. It’s not a new installation but it is a new problem.
von Janet
