Zum Hauptinhalt wechseln
Apple kündigte am 9. März 2015 an, dass das Retina MacBook 2015, Modell A1534 am 10. April herauskäme. Es hat eine neue Unibody Konstruktion und beinhaltet ein verbessertes Trackpad, Tastatur und Retina Display.
281 Fragen Alle anzeigen
Internal SSD missing - Not Seen in Boot Menu or Disk Utility
My Early 2015 MacBook just boots to the flashing folder and the internal SSD is missing from the boot menu and cannot be found in Disk Utility when I boot to an external Mac OS installer. Have tried resetting the SMC and PRAM and nothing changes.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Sadly, your systems built-in SSD has failed.
Did you have a liquid spill or sit your system down on a wet surface? Did you drop or bang your system?
If both are no, I would visit an Apple Store and ask them why the SSD failed as it shouldn’t have within less than 3 years!
While they may tell you is not covered under warranty, I would push a bit. Do keep in mind the cost of replacing the logic board is quite high and you may want to consider getting a different system.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
That's unfortunate. My advice is DO NOT accept "no" for an answer when you are asking for them to repair or replace your system for a discount or for free. Keep pushing until someone caves in and agrees to either fix your system or replace your system for a low cost or for free.
von
In theory the drive should be viewable in the recovery partition however try clicking on ‘view’ and show ‘all devices’
then quit and re-open disk Util and see whether the drive is viewable
Bewertung 0
1 Kommentar:
Yes I tried this, no luck. Disk utility only shows the USB Drive.
von
Antwort hinzufügen
William Emanuel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 1,257
