camera nikon coolpix p520 does not turn on
change battery and it does not work
Ist dies eine gute Frage?
First check the battery. Is it charged? Is it healthy or old and dead? If the battery is OK take the camera to a service facility; you cannot fix the insides of cameras, unless you are a trained camera technician.
War diese Antwort hilfreich?
Known problem... hundreds have the same problem with this camera... no known solving issue.. looking for an answer all over the internet... Even Nikon doesn't want to fix... new battery, received today... impossible to turn on camera
Talked to a Nikon repair guy: his simple answer … “it’s a contact issue” meaning the problem can be most likely solved with a soldering iron, reworking solder points one by one…
Letzte 24 Stunden: 3
Letzte 7 Tage: 11
Letzte 30 Tage: 39
Insgesamt: 3,386
