Zum Hauptinhalt wechseln
Die lange erwartete Neuauflage des beliebten Mac Mini. Er kann mit verschiedenen Prozessoren konfiguriert werden: 3,6 GHz Quad-Core Intel Core i3, 3,0 GHz 6-Core Intel Core i5 und 3,2GHz 6-Core Intel Core i7.
20 Fragen Alle anzeigen
Solder an external power button to the latest mini?
Hi y’all,
Just got the latest Mac mini and I need to add an external power button to it with long wires so I can turn it on and off from a distance. In the previous models I was always able to trace back the wires to the pins and splice the cables but with this ultra flat cable now, anyone knows where I need to add my wires?
Thanks a bunch!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
If you are trying to setup a media server (or other server) you can setup wake on LAN which is what I would do.
War diese Antwort hilfreich?
Bewertung 3
12 Kommentare:
Thank you @danj , I think I figured it out and I’ll post my result on this forum cause, hey, might be useful for others. This year’s Mac mini’s layout makes it difficult to figure out which pins are the button ones because of the 8-pin flat cable. But I think I found them. I’ll try to turn it on and let you know hehe
von
Do keep in mind if you alter the logic board or cable connection you will void your warranty!
von
@danj did they get rid of the IR control?
von
@mayer yes, they ditched the IR control. There is no more black piece of plastic under the sleep light which is where the IR sensor used to be.
von
Sadly, I don't see any sensor window in the IFIXT teardown. Bluetooth or WiFi would be the only way you might be able to turn it on remotely wirelessly. I have mine (2011) setup to wake on LAN.
von
7 weitere Kommentare anzeigen
So what was the solution? You wanted to post it…
Bewertung 0
2 Kommentare:
I’d love to know how to bypass the switch I broke mine. I juts need to get it turned on !
von
I also want to know this solution.
von
I created a Mac Mini M1/M2 Holder Vesa Mount with Switchbot and Servo Power Button Pusher you can print to use for this. https://www.printables.com/model/540401-...
Bewertung 0
Antwort hinzufügen
Jess B wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 27
Insgesamt: 2,099
