Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Half of the screen doesn't work!
Hi, so I dropped my iPhone 6 today and then later found out that the bottom half of the screen is unresponsive and doesnt work. I then went to several repair shops asking for a screen replacement but my phone is bent. Any way how to fix it? PLEASE REPLY.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
The first thing you would try would be to check if the cables are correctly in place. Open up your phone, disconnect the battery, then unplug the screen cables and reconnect them again. The next thing you would try would be a new screen. Try replacing your screen with this guide iPhone 6 LCD mit Touchscreen tauschen
Then, if that doesn’t work, then if would be a problem with the touch IC. You mentioned that your phone was bent. Can you see any weird grey bars on the top of the screen? That is often a symptom. Having a bent phone can damage the touch IC and display ICs, which stops the touch screen from working. If a new screen doesn’t fix it, I would suspect it is a problem with these ICs. It is a common issue in the iPhone 6, Bring it to a micro-soldering repair shop, and they should be able to fix this.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
PSDara wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 1,331
