Zum Hauptinhalt wechseln
Released in May 2014, the Chromebook 2 features an 11.6" display, Intel Celeron processor, and a 16GB SSD. Identified by model number XE500C12-K01US.
15 Fragen Alle anzeigen
How do I fix broken audio jack?
One day, I go to use my headphones on my Samsung Chromebook 2, but I am greeted with very distorted audio. I tried everything I could to try to fix it. (Wiggle the headphone jack, remove anything in the audio jack port, etc.) After a while I found out the the headphones work perfectly fine when the mic button is pressed on them. I tested another pair of headphones, and the same thing happened. It seems that whenever I use a pair of headphones with three plastic rings on the jack, the sound is very distorted. BUT, when I use headphones with only 2 plastic rings, it works perfectly fine. Any ideas?
(My headphones worked perfectly fine before, so something must have happened to my Chromebook port.)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Fixed by bending a piece inside the jack.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Tyler Meece wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 285
