The problem is actually in the entire design of the brush motor pulley system. While you think that the belt is the culprit, or even the gear on the motor or brush roller side, those are symptoms of the TRUE problem, which is that there is too much tension put directly on to the shaft of an inadequately hearty motor. I will, of course, explain...
Take apart the brush motor pulley assembly and you get down to the motor with a black shell screwed on to it by 2 smaller screws inside of the pulley housing. Take those off and you have the motor encased in a black rubber shell that holds on the thermal cutoff switch. Tug on the rubber and it will eventually loosen; it's just stuck at the screw holes where it's been screwed down tight against the motor for all of this time. That exposes the thermal cutoff, and you can undo the wiring harness from the motor at this point.
Now you will be able to see the problem: push the shaft to the side in different directions and you'll notice that the shaft clicks over about 1-2mm depending on wear, in the direction of the belt's tension pulling on it. That's where the shaft has been pulled hard against the wall of the bearing and just eaten through it over time until the belt goes slack. Once the belt is slack enough, those teeth start skipping, making that grinding noise, and wearing down the teeth to compound the issue. Replacing the belt is an exercise in a complete PITA vacuum teardown to get to the brush motor assembly for a very short term fix since it's already too slack and will wear down the teeth on your new one quickly. You COULD switch to a 134mm belt, but there is unlikely to be enough of the bearing rubbed through to give you an additional 2mm of slack and not cause the vacuum to throw a C 01 code from feeling the additional tension and thinking something is caught in the brush. The only fix is to replace the entire motor, and the belt in the process since it's likely been worn down, but the motor bearing is just going to wear through again over time and you'll be right back here. There is likely nothing wrong with the gears in the rest of the housing, so if anyone is able to source the motor by itself, that is the least wasteful approach to fixing it
Bottom line is this is a faulty design by Samsung and they will never acknowledge it. We paid $500 for a vacuum that will regularly be taken down hard by a $1 motor.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
0
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
1 Kommentar
same here, I just unplugged mine, tired it riding around dirty and not cleaning.
von Ben Reynolds
