Zum Hauptinhalt wechseln
LG 65LB730 Screen problems, pulsating
Hi, my TV have randomly started pulsating some lines on the objects.
I’ve tried to reset the tv to factory settings and also upgraded/downgraded the fw and problem still issue.
Clip on the issue.
https://www.youtube.com/watch?v=2gs6PVba...
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Jakob Vesterberg
this could be an issue with the main board. Try different video input sources (HDMI, Composite, Coax etc.) and see if it remains. If so, I would consider replacing the main board.
War diese Antwort hilfreich?
Bewertung 2
You are experiencing a TV with an LED problem. Very common. I have repaired these under warranty. Your TV panel is the culprit. You may try to replace the LEDs. This is extremely difficult and can result in a complete waste of time. Recycle and shop for new. Thanks for asking, Matt of Martins TV Repair.
Bewertung 1
1 Kommentar:
Then I know, thanks for the help :)
von
Antwort hinzufügen
Jakob Vesterberg wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 313
