It Wont turn off
My ipod wont shut off
Ist dies eine gute Frage?
weshoward07 it should turn off if you just hold down play button until it turns off. It is one of the early signs of upcoming malfunctioning iPod if it start with difficulty turning it off. Also try a soft reset by pressing the menu button and the center button at the same time.
Hold the buttons down for. Wait until the screen goes black and then the apple logo appears.
War diese Antwort hilfreich?
weshoward07,
Switch the hold on then off and try. If that doesn't work press the menu and center button at the same time and hold them until the iPod re-starts. After about 15 seconds you should see the Apple logo and it will re-boot. Start a song then pause it. Then press the play pause button and hold it and the unit should turn off. Then use the hold switch to keep it from turning on again. If this doesn't work you may need to re-set it using iTunes. Good luck and please let us know how you do.
Marc
Thanks - this one worked for me!
Thank you, trick is working...:)
Thanks after a few goes it worked
Thanks a bunch, man! Up until 3 days ago, I only had a 2005 iPod Shuffle, so I had no idea how to deal with anything with an LCD screen, iPod-wise (?
Thankyou so much. This worked perfectly for me
Had the same issue recently on an ancient iPod video. One of the pins at lightning port was bent. Bent it back, all is well.
Well, if you have a lightening port, it's may be old but not ancient.
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 75
Insgesamt: 59,648
