Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
Battery is not being charged while it says charging
I had repaired the charging port on my iPhone 6 after it had been damaged along with the screen. Everything worked perfectly for about 2 months, but then randomly stopped charging the battery even when it said it was charging. Is this a battery issue? The battery had been dying very quickly for awhile now.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Unfortunately trying to replace battery, after you replaced the lightning port, is the only attempt left on a DIY basis to see if the issue gets solved, but from your description there might also be a good chance there’s a logic board problem. Besides the bad hit, have you used uncertified chargers/cables to charge your iphone ?
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
I'm assuming you're right about the battery being the issue based on other research I've done. If this were to be a logic board issue though, what would you recommend?
von
@kaiserjesse If it was a logic board issue, the only real option you have is to find a lab specialized in microsoldering for repair. Boards for replacement market is limited and not cheap either.
von
Antwort hinzufügen
Jesse Collins wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 37
