Zum Hauptinhalt wechseln
Eine von Sony Computer Entertainment produzierte Fernsehspielkonsole; die PlayStation 4 Slim (CUH-2000-Serie) ist ein dünneres Ersatzmodell für die originale PS4. Angekündigt am 7. September 2016.
Why every time I start a game my ps4 shuts off without warning?
Why every time I start a game my shutouts off without warning. Its not an overheating problem . I checked.I tried switching outlets and using a power supply box and in combination worked but now it does not?
Ist dies eine gute Frage?
Bewertung 9
1 Kommentar
Every time i load in to any of my games it shuts off
von
Einen Kommentar hinzufügen
14 Antworten
Hilfreichste Antwort
Dear Escobar,
I read you facing problem, Its because of processor getting hot suddenly with heavy processing.
It can be fixed by cleaning all air path and cooling fan.
and use extra cooling fan from out side it will help you to keep your ps4 getting heat up fast.
War diese Antwort hilfreich?
Bewertung 2
7 Kommentare:
What if you cleaned the airways and the fan and it still does the same thing. This all started when I tried playing horizon zero dawn when the data for the application went corrupt and ruined all my data so I wiped the system and reinstalled all my data except for the horizon data . Was fine for about a day then I woke up to my system wouldn't turn on and when it did turn on it said there's an error and got stuck in this infinite loop . Well I rebuilt the database and it was fine again but now I suffer the same problem of when I boot up a game it'll shut down by itself . I can watch Netflix for hours and it's fine but once I try to boot up a game it powers down
von
I've been having that exact problem I'mma buy a new internal harddrive
von
Ps4 pro cuh-7015b
Starwars force works
Skyrim V and infamous Second son: both fail as soon a the online update downloads
If you run them the ps4 pro instant turns off.
All netflix Hulu prime apps work fine
Not on long enough for it to be a heat issue
Turn on with disc in ,launch game,system turns off
von
Had the same issue with original PS4, and found the fan was at fault, i found it beep a few times before switching off, have since replaced the fan and now is fine, also cleaned and re-added thermal paste to help with the heat........just got to fix the blu ray drive now as thats faulty.
von
@hypermechanic I am having the exact same problem , were you able to fit it ? Please help !
von
2 weitere Kommentare anzeigen
Put your PlayStation in Safe Mode And Update From The internet And it will
Fix Your Problem
Bewertung 2
4 Kommentare:
i was tyrna play fornite and it just shuts off my ps4 and everytime i try to go back in it dose the same thing
von
That's exactly what mine does. I start Fortnite and it shuts down!
von
I have this exact same problem, i’ve tried to start fortnite like 3 times and it goes to pre loading screen and then my game shuts off. ☹️
edit- TYSM! It worked!!
von
Ok nice but WHAT WORKED FOR YOU?? WHICH OPTION WORPT FOR YOU KISS I HAVE SEEN A LOT OF OPTIONS BUT YOU MENTION NONE OF THEM THE THERE ARE STILL PEOPLE WITH THIS PROBLEM SO IT WOULD BE VERY HELPFUL THAT YOU MENTION YOUR SOLUTION
von
I took it completely apart, cleaned all the dust out, and reapplied thermal paste to the APU(after cleaning the old gunk off). It works perfectly now.
https://youtu.be/KD5Ihb4Ou_Y
Bewertung 2
i had the same problem with my ps4 slim and what i did was simply remove the internal hard drive and first inspect it for any damage inside and out, and when i found none, l looked at its connection part. i saw it was burnt out so i immediately bought an external hard drive to save all my data and went online and bought a new hard drive. then, i simply connected the new drive and reloaded all my data. not only was i able to enter a game (after weeks) i was also seeing my playstation running faster, smoother, and all in all, better!
i’d highly recommend to do this.
Bewertung 1
Same problem with me I can watch movies I can play dvd games but when I start a game from system storage it’s shutdown I think maybe my hard drive have faults so I change it still same the problem is I find is a cockroach is make spark in power supply and make some parts damage so you need to change your power supply it’s will work fine
Bewertung 0
If you watch a movie on say Netflix does it stay on?
Bewertung 0
I had this exact same issue with a ps4 I bought 2nd hand, privately. a month after I got it it started randomly shutting off or putting it into rest mode, for about three months. none of the suggested remedies helped me.
A week ago I had the brainwave to blow out as much dust as I could, so that is what I did, with a small compressor I have. so far no problems at all……..5 days and counting.
Bewertung 0
Updated my firmware from safe mode and it works fine now
Bewertung 0
I think you should update to the latest version
Bewertung 0
It could possibly be over heating, it might be worth pulling it apart and cleaning all the dust out of the heatsink and the fan.
Bewertung 0
Yeah I had mine saying during games the ps4 was too hot although it was not hot to touch. Cleaned out the inside of dust and put it all back together again then upon starting it starts fine but soon as I start a game (RB6 siege) it gets louder and shuts off about 30 secs after loading the game any solutions or could it just be knackered ?
Bewertung 0
1 Kommentar:
Yea, you need to apply new thermal paste on the processor, it’s heating up too quickly. It’s been a while so you might’ve gotten a new system or managed to fix it already.
von
If anyone sees this, every time you take apart your ps4 for any reason you HAVE to replace the thermal paste or else you’ll cook the processor and then your ps4 will be completely dead. Anyway to answer this question it’s definitely the thermal paste, 99% of the time it’s the main cause of a ps4 doing this because the processor is heating up too quickly
Bewertung 0
This might not be the answer but it worked for me all I did was change the small battery inside the console and when I put it all back together I put a new battery in it's like a watch battery and then after left the bottom and the top part off and it works does it hasn't shut off yet I've been playing on it for about 2 and 1/2 hours
Bewertung 0
اطفاء جهاز بلاي ستيشن فجاه بدون اي سبب
Bewertung 0
Antwort hinzufügen
Jordan Escobar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 58
Letzte 30 Tage: 190
Insgesamt: 49,460
