Zum Hauptinhalt wechseln
Im Jahr 1991 für das Modelljahr 1992 gestaltete Isuzu den Trooper komplett neu, um mit den Veränderungen auf dem SUV-Markt Schritt zu halten. Er wurde größer, leistungsstärker und luxuriöser.
It won't start what should I look at?
I unplugged my battery & then plugged it back in, now it don't want 2 start..
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare
There is not enough information here to give you an intelligent answer. Please tell us the history and what it will and won't do.
von
Was running rough so changed over a months time several parts just for it not to start now. Changed fuel pump today now its not getting fuel to rail. New parts fuel pump ICM. ECM fuel filter injectors plugs timing changed. Please help before he decides to just shoot/tannerite it
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
There are many things to consider when a vehicle won’t start. If you were able to start the vehicle prior to the battery disconnect, we can start with some very common and easily diagnosed common issues. Start with the battery and electrical system. Check the battery voltage. Fully charged, the voltage should be 12.6 volts or higher. If the battery is dead, it can read anywhere from 0.0 volts to around 11.5. Even 12.0 volts could be insufficient to start the vehicle. If while disconnecting and reconnecting the battery you accidentally crossed the positive (+ Red) and negative (- Black) leads or disconnected positive first and it touched the frame, you may have either fried some wires, or more likely have blown fuse(s). Check some wires in the immediate area for burning or a burnt stench. Check your fuse box lid for a diagram and use it to reference locations for fuses related to starting the vehicle like the starter. I’m not familiar with this vehicle, but anything you find that you think may be related to starting the vehicle or essential for operation, you should check the fuse. Replace any fuses that are blown anyways once the issue is resolved. The community will need more information if this doesn’t help you. Consider offering information such as, when you turn the key, is it clicking, cranking over, or is it just plain silent? Do your headlights or dash indicators come on? Radio? Is there gas in the tank? I know, dumb, but important. Is there an aftermarket addition like a sound system or alarm system? Let us know and we should be able to further assist you. There’s nothing worse than a useless vehicle.
War diese Antwort hilfreich?
Bewertung 1
3 Kommentare:
My 1996 Trooper, had TOTAL tuneup but it started taking longer to catch on the ignition so finally won’t start at all. PLEASE HELP!!! Want my truck back
von
Well my Bighorn cranks but it doesn't start, I'm not able to detect the 5v to power sensors and the MIL (check engine light) no longer comes up, though a sensors is disconnected. Any help?? Only the Check Transmission light comes up now and I suspect it comes up because it doesn't see the 5 v signal from the ECM
von
Yes I do that and never started
von
Antwort hinzufügen
mona Maria gomez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 49
Insgesamt: 2,061
