Zum Hauptinhalt wechseln
Manche Geräte lassen sich einfach nicht zuordnen.
253 Fragen Alle anzeigen
Can you tell which of these two cheap 2.1 amp board is better?
Can you tell which of these two cheap 2.1 amp boards will produce better sound by just looking at their components? (see pictures below)
TPA3116D2 VS TDA2030A
https://www.lazada.com.ph/products/ycrow...
https://www.lazada.com.ph/products/i2098...
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It would be nice if you included a link to these boards so that we could evaluate them better. The one on the left has a better layout, showing some attention to detail that hopefully gets transposed to the design aspects.
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
I agree, the one on the left shows thought and engineering skill.
von
Agreed with the one on the left looking more organized. Only drawback I see is with the screw connector on the left front corner on the left board. It would require special care in the design of a case. As @refectio mentioned, it will all depend on the specs of those boards.
von
Antwort hinzufügen
tri5kmark wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 131
