Zum Hauptinhalt wechseln
Aktualisierte Version des Retina MacBook 2016. Modell A1534, EMC 3099. Jetzt mit schnelleren Kaby Lake Prozessoren bis zu 1,4 GHz Core i7 mit Turbo Boost bis zu 3,6 GHz und bis zu 50 Prozent schnellerer SSD und unterstützt bis zu doppelt so viel Speicher.
72 Fragen Alle anzeigen
MacBook has not been charging and is shut down
My MacBook has not been charging with a USB-C cable. I have tried multiple cords but none have worked, it is a problem with the computer itself. I looked into the charging port and there is no debris. It is out of battery so I cannot turn it on, I am not sure how to fix this.
Thank you!
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Does your MacBook charge when you connected your AC adapter to another USB-C port? They all can operate in both modes as a data transfer interface and as a charging port.
Also there’s catch with MacBook chargers… Inside of those cables (in USB-C connector, to be exact) is a controller that basically decides how much power will adapter provide… And the stupid thing is that those controllers are all locked only on one specific number of watts (45, 65 or 85), so they are not interchangeable that easily… Louis Rossmann covered that topic with more detail. But if you know someone who has an USB-C capable monitor that can also charge laptop, try that. Or ask someone for their charger for testing purposes (don’t forget to return, though :P). If nothing works and MacBook won’t boot while plugged in to AC, then you have faulty power controller, looks like. After that you did everything you could, and now go to a repair shop with decent reputation (not Apple Stores or AASPs, that won’t end good).
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
desafortunadamente no fue util lo que me queda saber es si elprovlema es la bateria. lametable los talleres de "REPARACION " para productos Apple no son confiables y en muchos casos el remedio ofrecido es peor que la enfermedad, estuv confiado que la bateria seria el problema, otras pruebas que hize no funcionaron solo me que la duda de la bateria.
Confie de que el problema era el ADAPTADOR y como no podia verificar decidi en mi viaje a California comprar uno nuevo y no fue asi solo que me queda abrir la computadora y sacar la bateria y y testear para saber si finalmente es el problema. etc.
von
Antwort hinzufügen
Christine Hagan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 6
Insgesamt: 182
