screen totally not responsive but is lighting up.
screen totally not responsive but is lighting up. and the start up is a bit slower than normal
Ist dies eine gute Frage?
Hello Enzo,
Did the unresponsive screen and the system slowdown occur at the same time? If so, both problems will likely be solved with a factory reset. This sounds be doable without a working touch panel. On many Xiaomi phones, you can get into the recovery many by pressing this button combination. But if it does not work for you, Google "my model recovery and h
1. Hold the power button+ volume down button until the phone restarts.
2. Use the volume buttons to select “recovery”
3. At the Android character, press power button
Now, if you successfully reset the device and your touch is still not responding, you may need a new screen.
War diese Antwort hilfreich?
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 6
Insgesamt: 479
