Zum Hauptinhalt wechseln
The HP Pavilion g6-1b79dx is a 15.6” laptop with a pewter finish made in 2011. It has an integrated webcam and an Intel Core i3 processor.
Why is my laptop not booting
I converted this into a mini cpu by disconnecting the monitor display off from the board. One day it had a BSOD i didnt see the error because it shut down immediately. I cleaned its board and RAM but it’s no good. I cant identify the problem because im using external monitor to use it but i cant display even the BIOS of this one. What could be the problem of this?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Usually, laptop boards don’t require an internal display to boot, but you’d better to reconnect it to see if it gives something new (assuming, of cource, that you didn’t throw it away). If nothing helps, try to disconnect BIOS battery (usually it’s CR2 battery), wait for a while so that it could drain all energy stored at capacitors as leftovers, connect everything back again (including internal display if possible) and turn on. If that didn’t help, then you might have damaged your MoBo physically somehow, and the only way is to either forget about it of give it to reputable repair technician and see if he finds something (and fix it if he/she can).
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Laurence wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 42
Insgesamt: 417
