Zum Hauptinhalt wechseln
Der größere von Apples MacBook Air Laptops mit Doppelmikrofon und 802.11ac Wi-Fi Konnektivität.
465 Fragen Alle anzeigen
Where to order Batteri connector
Hi..
Please help!
I found this at this page (good page) :
Is it possible to replace the battery connector on the logic board
But I can’t find where to buy the connector. I search after S9B-ZR-SM4A-TF at google but a lot of pictueres of different connectors..
Is there someone who knows where to order the connector you talk about ?
S9B-ZR-SM4A-TF
Or is it 358 MA ?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Even if those are possible to find, buy and solder to mobo, it would be a such time-consuming task no one will try to do that. Either find a donor board (that gives you the biggest chances to get that part) or ask someone to hardwire a new battery (since connectors are made of plastic, they are easy to screw up with soldering iron, which is why the chance to find someone able and wishful to do that is pretty low…
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Jonas A wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 323
