Zum Hauptinhalt wechseln
A tablet with capabilities to attach to a portable keyboard and function as a laptop.
bios not detecting hard disk
Ok, I have a Lenovo Flex 4 15" 2in1 laptop which I had two years but after the first year it would not fully load maybe because of connection, (maybe). Yes it will still power on. Now after some time I realized my Bios setup did not recognize are was not communicating with the hard disk . At first, thought hard drive was bad but it wasn't. Have anyone had this issue and can help me. Your help will be a blessing too me.
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare
When you turn on your computer, it show you a message like no hard drive detected ?
von
no just the name of my laptop
von
Have you tried to set default settings of the BIOS ?
von
when i go to bios it keep asking for password which i do not have
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Alternatively, you can try manual methods to fix this error, but if they do not help, then you need to change the Hard Disk.
Check the data cable
Check the Jumper Setting
Check for Auto Drive Detection
Check if the Drive is spinning
Generally, if the hard disk is not recognized by the BIOS, you have a hardware failure. For example, the Hard Disk is dead. In this case, you’ll need a new hard disk.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
WILLIAM WALKER wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 23
Insgesamt: 382
