Zum Hauptinhalt wechseln
Vizio 42" LED TV released in September 2012.
45 Fragen Alle anzeigen
Colorful vertical lines started appearing on my TV
I turned on my TV yesterday and they started working perfectly fine then it turned off by itself I turned it back on after like good 2 hours and colored vertical line started appearing only when I turn on my Xbox that's hooked up to it it's the only time we'll start going off I tried with my we start doing that too and I try to keep my PlayStation start doing that also I need some help how do I get rid of them cuz I just got this TV
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
If you just got the TV, does that mean you just bought it or got it used? If you had just bought it, take it back to the retailer and ask for an exchange as it’d be under warranty I’d assume.
However, if not, make sure all connections are tight, and try a new HDMI cable.
However if you tried both of those and none of them fix your problem, you may need to look into either finding a LED screen that supports it and repairing it yourself, or take it into a TV repair shop.
Hope I could help.
War diese Antwort hilfreich?
Bewertung 1
On TV, make colors settings, not working
Update (07/03/2022)
This is my phone number6822607730
Bewertung 0
Antwort hinzufügen
tyler makar wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 254
