Zum Hauptinhalt wechseln
Wi-Fi Version des iPad Air 2, Modellnummer A 1566.
214 Fragen Alle anzeigen
Ipad Air 2 touch ID not working after screen change
Hi all,
Changed the screen on a ipad air 2, which you need to remove the touch id home button & flex from the old/damaged screen to place on the new, but after doing so the touch id no longer works, I have double checked the connectors, flex etc and see no signs of any damage so not sure what else to check.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Have you tried it with the original screen to see if it works?
War diese Antwort hilfreich?
Bewertung 0
Unfortunately the most likely situation with this iPad is that the home button was damaged when it was removed from the original screen, and this cannot be repaired. If it does not work as a home button you can either replace it or use the 5 finger gestures.
iPad Air 2 Home Button and Gasket Assembly
iPad Air 2 Home Button and Gasket Assembly Bild
Produkt
$19.99
Bewertung 0
1 Kommentar:
Note, the replacement button will only act as a home button, not touchID
von
Antwort hinzufügen
colin wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 418
