Zum Hauptinhalt wechseln
Can't find a reliable place to buy this motor.
I’m working on a roomba-like vacuum cleaner that ran over one of those sticky mouse traps, so the owner put it in the dishwasher. Anyway, I cannot find where to buy one of the motors pictured below without buying in bulk (30,000+ pack) from a manufacturer. If anyone could find where I can buy one, that would be great.
with or without the encoder board is fine.
Only thing on it is:
STANDARD MOTOR
RP390-ST/20143/DV
SMHD216804 RoHS
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
I’m searching this motor too…. Where i can buy it?
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
If the armature doesn't spin, soak it in WD40 for a couple days to free it up. Once it spins, use an ohm meter to check for dead spots. If a brush type, could have burned a winding. If it looks consistent, I'd disassemble motor and clean / lube everything.
War diese Antwort hilfreich?
Bewertung 2
You can desolder the PCB, but you need to know which is positive and which is negative or it’ll run backwards; motors do not care, but reversed polarity will result in reverse operation.
That looks like a pretty standard motor to me just from how it looks. If you can get the dimensions of it from the specific part number, finding a replacement won’t be hard. Just be careful how you remove the drive gear on the motor or you may break it.
Bewertung 2
Antwort hinzufügen
Aiden wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 3,109
