Zum Hauptinhalt wechseln
Die Apple Watch Series 1 ist eine Überarbeitung der ursprünglichen Apple Watch, sie wurde am 7. September 2016 angekündigt. Die meisten Teile sind die gleichen wie bei der Series 2
Power cycling before and after battery replacement
In my repair shop I don’t work on Apple Watches but I did replace the battery on a Series 1 for a friend who had purchased a replacement battery on his own from iFixit. The watch after having set unused for several months would power to the Apple logo then shut off. I told him I thought there might be more to it than needing a new battery, but since he had purchased one I would install it for him.
The physical replacement went well and I got the watch back together fine (actually easier than I anticipated getting into the watch). When I first put it on the charger (OEM charger and cord by the way) I got what people have termed the “Green Snake of Death”. My amp meter after some initial swings seemed to settle in at around 0.32amps with occasional moments of zeroing out. Even when leaving it on the charger for an extended time I never noticed the watch getting excessively warm. Overall, I assume the battery was charging. After multiple attempts I have not seen the “green snake” anymore and now the battery will at times power to the Apple logo and turn off (never actually power cycling though on it’s own). So basically it appears to be at the same status as before the replacement.
Has anyone been successful getting beyond a similar situation on a consistent basis? I assume that as with the iPhone there is logic involved in the whole charging system and that somewhere an IC on the motherboard, the battery and the charger are not communicating with each other correctly. Any ideas? Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
I’m having this issue currently. Can anyone confirm any actual fixes for this issue?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Since the iWatch batteries are cheap, I’d try another battery just in case you happened to get a bad one from iFixit. I have had this happen more times than I can remember with iPhone batteries.
War diese Antwort hilfreich?
Bewertung 1
5 Kommentare:
I am assuming that ifixit covered the batteries under warranty?
von
Yes they did.
von
does another battery made your watch work again? Im facing similar issue.
von
it it really a batterie topic=
von
I’ve went through the exact same thing only without a batty replacement, I never used my series 1 for near 5 months, When i wanted to use it again i started to charge it only for the Green Snake to appear then blank Screen(Face). After a short time charging an Apple logo started to appear randomly and again blank Screen(Face).
The Apple Watch doesn’t seem to be making it through the original charge causing it to repeatedly try to start with minimum power and doesn’t. Overall, I assume the battery was charging. After multiple attempts I have not seen the “green snake” anymore and now the battery will at times power to the Apple logo and turn off (never actually power cycling though on it’s own). I’ve done all the 4 recommendations from the Apple Help section without success, Now I’m thinking it’s a software issue, I’ve been on to Apple Site stating Charging & Battery Issues and they’ve been great help sending me packaging to look at it with no cost which is Excellent ?
von
Antwort hinzufügen
Gregory Harris wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 22
Insgesamt: 1,952
