Zum Hauptinhalt wechseln
A 64.52" LED 2160p 4K UHD Television released in 2015.
13 Fragen Alle anzeigen
must power cycle to get pix
VIZIO P702ui-B3 If off for more than a few hours the led (lower left corner) lights, Audio works, but no picture. If power cycled 2 or 3 time it turns on normally.
This happens with the remote or the manual switch on the set.
I’m thinking about replacing the power supply. Could that fix it or perhaps the Tcon board?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I had a similar problem with my P55-C1 (audio, no picture). I used a flashlight and discovered that the picture was actually working but the backlights weren’t coming on. I replaced the LED driver boards (four of them) and now I have a working picture again.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
where do you find a driver board? Would you post a tutorial on replacing it please?
von
Antwort hinzufügen
Greg “Bad Kitty” Arikian wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 319
