Zum Hauptinhalt wechseln
Vorgestellt am 16. September 2016. Modelle A1661, A1784 und A1785. Verfügbar mit 32, 128 oder 256 GB internem Speicher in den Farben Rose-Gold, Gold, Silber, Schwarz, Diamantschwarz und Rot.
Can I upgrade iPhone 7 plus 32gb to 128gb by logic board replacement
I have a A1784 iPhone 7 plus and I need to replace the logic board
While I’m at it I was thinking of buying a 128gb logic board to upgrade instead of the 32gb which is what my phone originally had. If I did replace the 32gb one to 128gb would it be compatible? Would it be compatible with the 256gb one?
Thanks in advance
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Yes its possible, dont forget to transfer the home button also, it is paired to the logic board.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
You also need to make sure you get the exact same version as there is four different radios. Review your phones specs here: Everyi - iPod, iPhone & iPad Specs - By Identifier
von
Hey Matt W,
Yes, a 128GB logic board from the same model (A1784) should be compatible with your 32GB iPhone 7 Plus. However, certain components like the front camera and Touch ID sensor might need to be transferred from your original logic board for them to work properly.
but it's not officially supported by Apple and can be tricky.
Bewertung 1
Antwort hinzufügen
Matt W wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 1,587
