Zum Hauptinhalt wechseln
12.1 MP camera with 3x optical image stabilized zoom. Released February 2009.
4 Fragen Alle anzeigen
Canon SD780 IS service manual?
Anyone knows where I could get the service manual or a take apart guide for the Canon SD780 IS ? I need to replace the flash unit on this one.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
6 Antworten
Gewählte Lösung
This is what I was searching for:
http://www.youtube.com/watch?v=B4GGhTTN1...
War diese Antwort hilfreich?
Bewertung 4
cant locate a manual so far but THIS may help you.
If you do take it apart perhaps you can start a guide here at iFixit
Also there are many similarities between models so THESE existing guides may be useful
HIH
Bewertung 3
1 Kommentar:
thanks for the links Richdave.
von
There are several websites that have the owners manual. Here are some:
http://gdlp01.c-wss.com/gds/4/0300002064...
http://www.lib.jmu.edu/media/documents/C...
Bewertung 1
1 Kommentar:
Mark Thompson, the OP was wondering if "I could get the service manual", not the owners manual 2 1/2 years ago:-)
von
Look here: http://www.smpcshop.com/Canon-PowerShot-...
Bewertung 0
thanks a lot
The top-end successor to the IXY DIGITAL 210 IS released in February 2009, the 220 IS features not only a an expanded 2.7-inch Clear Live LCD II monitor and newly designed 4x zoom lens that supports wide-angle 28 mm* shooting for increased lens power, but does so while maintaining a slim body measuring 20.0 mm thick. The model’s smooth, stainless, and sleek exterior comes in four different color variations.
http://www.canon.com/camera-museum/camer...
Bewertung 0
When using an Eye-Fi card with the Canon PowerShot SD780 IS / IXUS 100 IS / IXY 210 IS, it is best to adjust the power settings so that the camera does not turn off before transferring has finished.
Bewertung 0
Antwort hinzufügen
lemerise wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 3,536
