Zum Hauptinhalt wechseln
Dritte Generation des Surface Pro Tablets ab 20.Juni 2014
123 Fragen Alle anzeigen
How to test the battery pack before replacing it?
I have a dead Surface Pro3, presumably with a defective battery pack. After many months of looking at it I took the plunge, broke through the screen and have the battery tail with its connector free. The main connector tabs show zero volts but Im not sure if this indicated a dead cell or that I am not enabling a switch within the battery management scheme which is part of the battery pack.
Can anyone tell me if the battery tail should be at 7.5V standalone, ie how do I test the battery pack before trying to replace it?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
In Windows 10 you can open a command prompt with admin priv and type powercfg /batteryreport /output "C:\battery_report.html
War diese Antwort hilfreich?
Bewertung 0
no directly replace it, without doing any test, as you already said the battery is dead so there is no reason to test it, a dead battery could also harm your surface pc , so be cautious.
Bewertung 0
Antwort hinzufügen
Tom Nicols wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 60
