Shark Navigator Freestyle cordless stick vacuum offers portability and easy maneuverability. The vacuum can be identified by its model number SV1106 and sleek figure.
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
2 Kommentare:
Could you post a picture of the part you were disassembling? It might help to see where a spring could've potentially gone.
Same happened to me. Vacuum still turns on when I have the bottom disassembled (white top unscrewed from gray bottom) and I push the on/off switch there. Ever since I disassembled and a spring popped out the on/off button will not start the vacuum. Any tips? Where do I put the spring back for a vacuum to turn on using on/off button?
von Alec M
von Rebecca
