Zum Hauptinhalt wechseln
The Lenovo IdeaPad 110-15ISK was developed in the United States by Lenovo in 2015. The Lenovo IdeaPad 110-15ISK can be identified by its model number: 80UD.
10 Fragen Alle anzeigen
How/where to fix a Chipped Bottom keyboard of Lenovo Ideapad 110
Hello,
My laptop is fairly old and has been through some tiny drops but recently it fell off a table onto the concrete… there is a fairly decent chip that has come off of the bottom where the power button is and I can see the internal hardware. Is it worth even going to get it fixed? Also where to fix it? The screen and keyboard still work, I’m more worried about stuff getting in there or it breaking more.
Any help would be much appreciated :)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Can you show a picture if the chip? Thanks
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi,
If you have an IdeaPad 110-14ISK or 110-15ISK then if it is the upper case where the problem is, here’s a link to the service manual for your laptop.
Scroll to p.56 to view the necessary pre-requisite steps and then the procedure to remove/replace the upper case.
On p.71, item #3 you find the part number(s) for the upper case. (FRU number)
If you search online using the appropriate part number only in the search box of your browser, you’ll get results for suppliers of the part.
This may help you to decide if you wish to replace the part or not ;-)
War diese Antwort hilfreich?
Bewertung 2
If its not a very big chip I wouldn’t bother. If it’s medium sized DO NOT IGNORE IT. I made the same mistake with my laptop and It quickly died. I would think the best place to fix it would be where you brought it *do they do repairs where you purchased it?* Also noting what I said earlier if it’s not that big nothing can get in. The worst that can happen is it may freeze for a few moments during the boot up. If its big get it fixed as soon as possible.
Bewertung 0
1 Kommentar:
hope this helped.
von
Antwort hinzufügen
Cierra Hunter wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 142
