Zum Hauptinhalt wechseln
Reparaturanleitungen, Informationen zur Demontage und Fehlerdiagnose für das Apple iPad der zweiten Generation mit CDMA-3G-Mobilfunknetz (Verizon), erhältlich mit 16, 32 oder 64 GB Speicher. Ausgestattet mit einem Dual-Core Prozessor vom Typ A5. Erschienen im März 2011. Identifiziert durch die Modellnummer A1397. Reparaturen erfordern Hitzezufuhr und vorsichtiges Hebeln.
Ghosting and screen randomly switching to different things
The screen randomly selects different points on the screen and goes to these selections even though it didn’t touch them . Or has a problem going to what i select. Like swiping the screen to let me into the the apps after startup.
I did replace the digitizer and added the orange tape to the silver edges of the inside of the glass. Although i can see some edges of the silver metal. Would that be enough to still cause the ghosting ? The black plastic replaceable edge around the digitizer was having trouble sticking to the frame so the glass was not totally sticking to the ipad. But this was slightly noticeable. It would get worsen as the ipad stayed on longer, then randomly go to other screens. Thanks for your help
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
The digitizer that ifixit sells is NOT bronze colored either. So i will reapply wider orange tape and see if the changes anything. I have one more probably came from the same place the first one did. I will come back and let youmknow what’s happening. Thanks everone , much appreciated you inputs.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
It’s probably just a bad digitizer.
So start by checking that the connectors are properly seated and don’t have any damage. After that, you’re next step is to try another digitizer.
War diese Antwort hilfreich?
Bewertung 5
3 Kommentare:
Hmm...I could be wrong, but I don't think the iPad 2 digitizer in particular has bronze edges.
von
You're probably right...I won't bet the mortgage on it ;>). It was more of a reflexive answer. I just checked my inventory, from multiple suppliers and they are all silver. I'll edit the answer appropriately. Thanks!
von
So I replaced the digitizer with another one from the same vendor. And it works just fine … for now. But looking to wait to see how long it does. It’s scary to think anything from any vendo has such a lack of quality control. For instance i bought 2 ipad 5 home buttons and one of them didn’t work. So not really wanting to buy double of everything just to get one part that is good. So thanks everyone for your help. Jury still out on this one.
von
Antwort hinzufügen
Perry Green wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 384
