Zum Hauptinhalt wechseln
Zweite iPhone Generation. Modell A1241 mit 8 oder 16 GB Kapazität und schwarzer oder weißer Kunststoff-Rückseite. Die Reparatur ist leichter zu bewerkstelligen als beim iPhone 1. Es werden Schraubendreher, Hebelwerkzeuge und Saugnäpfe benötigt.
1158 Fragen Alle anzeigen
Battery shows it is connected to charger but will not charge up
My iPhone battery quit charging so I ordered a replacement and it worked for a day and then the phone would not charge again. Any ideas about what else could be causing the issue, I took the phone apart again and doesn't seem to have any loose connections.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
First try with a different charger, if that doesn't work replace the dock connector and if that doesn't work order a new battery. I prefer this order as a new dock connector is easier than replacing a battery and trying a different charger/plug socket is the easiest of them all!
It may also be a good idea to look inside the dock connector for fluff and bits of tissue from your pocket and clean these out as they can occasionally prevent charging
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
What if your phone lights up when u connect the charger but the battery never gets charge? If it's the dock connecter is it still possible the phone would light up and show the battery symbol?
von
Watching this can be helpful:
http://www.youtube.com/watch?v=FW72sDTYi...
If all else fails you can just purchase a new dock connector, I just replaced mine a few min ago and it charges like a champ now (oh btw I had similar problem)
Bewertung 0
battry charger not
Bewertung 0
Antwort hinzufügen
mustang3372002psenter wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 8,750
