Zum Hauptinhalt wechseln
This is a humidifier with the an R2-D2 theme and appearance. It is produced by Emson.
2 Fragen Alle anzeigen
Where can I get a replacement cord?
We lost the power cord to our R2D2 humidifier.
Where can I get another one?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
You can try a variable ac-dc power adapter then set it to the rating. This is the information I could find in a manual on google.
I’m not sure if the dc connector from this one will fit, you will need to find out the size of the end connector.
https://www.amazon.com/OMNIHIL-Adapter-C...
“ To avoid fire or shock hazard, plug the AC Adapter into the humidifier then plug the humidifier direct to a 120 VAC or 240 VAC electrical outlet. “
Please reference the manual before executing anything. Remember V=IR, P=IV, https://www.sharperimage.com/si/pdf/manu...
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Grrrouch64@columbus.rr.com wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 321
