Zum Hauptinhalt wechseln
Samsung Series 5 3G Chromebook. This laptop has a 12.1" Super Bright high-resolution, non-glare display ideal for web browsing.
8 Fragen Alle anzeigen
Where's Developer Mode Switch?
The Developer mode switch is supposed
to be in the battery compartment or
behind a removable panel.
It's a very important feature and you
don't mention it all. where is it
located at?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
mine was a device that had no switch near the sim , instead it was inside the small hole in the case to the right of the power button
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
The dev switch is accessable without opening the device. It is on the right hand side of the device behind the SIM slot cover.
Edit: You can see it right below the SIM slot on the Step 14 teardown picture.
War diese Antwort hilfreich?
Bewertung 5
2 Kommentare:
I Have a chrome book and have looked behind the panel where it is supposed to be and there is not a switch there, the hole is but there is not a switch to use?
Any ideas?
von
robert clench, did you confirm this by checking the image of the teardown?
von
From what I've read, the developer switch is only on the CR-48 (Prototype/Developer Chromebook) It isn't found on retail models.
Bewertung 1
1 Kommentar:
Not according to what's stated in here. http://goo.gl/b2Fl2
Shell access is only available in Dev mode, if it's not included, a lot of people are going to be angry.
von
The Dev Switch Is On The Right Side Of The Unit, Where The Sim Card Slot Is Located, It's A Switch That Can Be Toggled With A Pin (Paper Clip) Or The Tip Of A Pen.
Bewertung 0
4 Kommentare:
So you are confirming what "no way" answered in June of 2011 correctly. Good Job ;-)
von
Wow apparently so , I guess that's what happens when you don't bother to read all posts. My apologies.
von
Yup, happens all the time ;-)
von
how do u use the switch
von
Antwort hinzufügen
William Greene wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 11,104
