Zum Hauptinhalt wechseln
Kinect is a gaming peripheral for the Microsoft Xbox 360. It allows for audio and video input to let the player be the controller.
20 Fragen Alle anzeigen
What are the physical dimensions of the Kinect device?
What is the height, width and depth of the Xbox Kinect camera, and does the cable require you additional clearance from the wall beyond the overall depth of the device?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
Of course you are asking this because you want to either repair it and/or incorporate your Kinect into a different entertainment center, thus making it repair related? ;-)
von
The height, width, and depth of the Kinect itself should be listed in its user manual. Look through it to see if it's listed.
If not, a search on Google should bring it up.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Michael Emery, just measured mine :
Length 11"
height 3"
depth 3" at the widest part (the base)
the cable exits from the rear of the base, so you would have to give it some extra depth to accommodate it. Good Luck and I hope this helps.
War diese Antwort hilfreich?
Bewertung 3
420 cm hieght
420 cm lenght
420 cm depth
just measured her up braz
Bewertung -1
2 Kommentare:
Thank you this helped a lot
von
@blazeit your measurement make the Kinect a cube. You want to double check this? You also want to refrain from having your super ego vote up your wrong answers.
von
Antwort hinzufügen
Michael Emery wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 19,250
