Hi,
Try a power refresh and check if this resolves the problem.
Here’s how to do this:
Remove the main battery from the laptop
Press and hold the laptop’s Power button for 30 seconds to drain any residual power from the laptop.
Connect and switch on the charger to the laptop and try to start the laptop. (leave the main battery out at this stage)
If it still doesn’t start, switch off and disconnect the charger, and then disconnect the RTC battery (CMOS battery) from the motherboard and press and hold the laptop’s power button for 30 seconds.
Here’s a link to the service manual. Scroll to p.65 to view the necessary pre-requisite steps and then the procedure to remove/replace the RTC battery. Take note of the orientation of the battery connector before you remove it, so that you re-insert it the correct way.
Then reconnect the RTC battery, reconnect and switch on the charger and try to start the laptop.
If the laptop starts, allow the laptop to boot all the way to the Windows desktop, allow the HDD activity to settle and then shutdown the laptop in the normal manner.
When it has completely shutdown, switch off the charger and reinsert the main battery into the laptop.
Switch on the charger and then try to turn on the laptop.
If it starts allow the laptop to boot all the way to the Windows desktop, allow the HDD activity to settle and then check the charge status of the main battery. If it is charging, allow it to fully charge before disconnecting the charger.
Also if it now works OK, it may be that the RTC battery is failing (or has failed) and needs to be replaced.
The RTC battery is non rechargeable battery that has a life span of 5-7 years approx. Once it gets too low (or is flat - no pun intended) it is possible for the BIOS to become corrupted and prevent a normal startup. Removing the RTC battery allows corrupted BIOS settings (if any) to revert back to their factory default condition.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
