Zum Hauptinhalt wechseln
Dokumentation und Anleitungen für die Reparatur des am 22. September 2017 veröffentlichten iPhone 8. Modellnummern A1863, A1905.
873 Fragen Alle anzeigen
Phone not charging after screen repair
Any ideas why phone is not charging after screen assembly replacment. Its stuck on 1 percent battery life???
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare:
thing is phone switches on when i plug in the charger but its stuck on 1 percent??? Any ideas
von
Help..the chip was replaced but i am being to that the phone still wont charge..does this mean the phone is ruined?
von
A reputable shop who repaired it should have checked that it charged after repair. What did they say?
This should be repairable.
von
they said the component is still in place but slightly damaged and cannot be fixed.. i dont accept that, what do u think?
von
Einen Kommentar hinzufügen
2 Antworten
I think you have damaged a chip on the board or not seated the battery connector properly.
War diese Antwort hilfreich?
Bewertung 0
3 Kommentare:
:(.. i hope its not the chip. Bit if it is any possibility of getting a possible logic board replacement, i will disconnect and have a look and reconnect it again...
von
thank you chris
von
Chris thing is phone switches on when i plug in the charger but its stuck on 1 percent??? Any ideas
von
no need for a replacement, a good repair shop that does microsoldering can repair for you
Bewertung 0
Antwort hinzufügen
Tracey Homeward wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 4
Insgesamt: 152
