Zum Hauptinhalt wechseln
Die kleinere Version des iPad Pro, herausgekommen am 31. März 2016. Ausgestattet mit einem 9,7" Display, dem A9X Prozessor und wahlweise mit 32/128/256 GB Speicher. Erhältlich in Silber, Grau (Space Grey), Gold und Rose Gold.
147 Fragen Alle anzeigen
Home button doesn't work when installed in place
So on my iPad Pro, whenever I install the home button with the bracket and everything, it doesn’t work. But when I take both out and click it with my hand manually, then it works. How do I fix that? I thought it was pressure at first but when I install it, it doesn’t matter how hard I press on the bracket, I can’t get it to work. The button clicks but the iPad doesn’t register it. Unless I click by hand when I take out the bracket.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
5 Kommentare
"Doens't work" is a vague description, we need more details: does the home button click when you press it? or it clicks but no response in the system? what about the touch ID?
von
Updated! The button clicks but the iPad doesn’t register it. Unless I click by hand when I take out the bracket.
von
@taziamoma That is very odd, I never encountered this issue before, sorry :(
von
@sammyz me neither. I'm completely stumped. What do you think it could be?
von
@taziamoma My first thought is the pressure. But since you mentioned that was not the case, I'm baffled as to what the cause may be, let's get some input from @refectio
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
The bracket is off center when you are putting the screen back on and something is pressing on the opposite side. It’s happened to me before.
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
Do you think a missing gasket seal would cause this?
von
For sure. It's totally possible. The variance on getting that button to push down properly is miniscule. No gasket would definitely change that variable.
von
Antwort hinzufügen
Taz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 93
