Zum Hauptinhalt wechseln
Herausgegeben am 25. September 2015. Model A1687/A1634. Die Reparatur des 6s gestaltet sich ähnlich zu denen früherer Generationen; benötigt werden Schraubenzieher und Hebelwerkzeuge. Verfügbar mit GSM oder CDMA / 16, 64 oder 128 GB / Silber, Gold, Space Grau oder Roségold.
2690 Fragen Alle anzeigen
Microphone Muffled and Speaker Low after replacing charging port.
I used a heat blower to open my iPhone 6s because it was never opened before. The adhesive loosen up and allowed me to open it up. Changed the charging port with no problem. But then the microphone got muffed and speaker head went really low.
Any suggestions?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You may have a defective replacement part or you could have installed it incorrectly. If you still have the original, you could install that one again to see if you have the same problems or not. While you’re doing this, check to insure there is nothing clogging the holes for the microphone and speaker.
My concern is that you used heat to open up the phone. If you applied too much heat, you may have melted some plastic parts near the microphone and speaker and that could be the issue.
War diese Antwort hilfreich?
Bewertung 3
2 Kommentare:
Hey Thanks for giving me back any feedback.
Moving forward, do you think I should get the heat bag from ifixit? Would that be less damaging on any other phone I end up fixing?
von
Heat guns work fine but it's hard to gauge how much heat is delivered. With experience, it can be a very fast technique. For one time or occasional use, then a heat bag is more controllable as the maximum temperature is more consistent. I started with a Magic Bag (for aches and pains) which had more surface coverage than the iOpener (and you get to use it on a tired body at times).
von
Antwort hinzufügen
rrodriguez0990 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 189
