Zum Hauptinhalt wechseln
Dritte iPad Generation, 4G fähig, Modellnummer A1430, erhältlich seit dem 16. März 2012. Die Reparatur erfordert Hitzezufuhr und vorsichtiges Hebeln.
Replaced digitizer starting to fail
iPad3. Last year I replaced my digitizer/screen with a new iFixit digitizer. Now, the left edge of the digitizer is dead to touch. The dead zone started about 1/8” wide and has grown to about 1/4” wide. Meanwhile the right edge is doing the same thing, about 1/8” wide.
I keep it in a wraparound case and I noticed the left edge is starting to come unglued. Is this related? Can I fix this somehow, or do I need another digitizer?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Hi @wolfharper ,
I suggest that you contact ifixit regarding the problem with the touchscreen “dead zones”. It never hurts to ask
According to their iPad 3/4 Screen Digitizer parts information, there is a lifetime warranty on their parts
Replace a scratched or cracked front glass screen digitizer panel. This part is compatible with a 3rd or 4th generation retina display model iPad. Bild
Produkt
$24.99
War diese Antwort hilfreich?
Bewertung 2
Try re plugging the screen back in. If it doesn’t work, you will have to replace the digitizer again . Let me know results … thank you
Bewertung 0
1 Kommentar:
Yeah digitiser needs to be replaced. I always add b7000 glue on bottom left and clamp down for a while to avoid this problem of the glass getting pushed up via the cable.
von
Antwort hinzufügen
Wolf Harper wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 321
